AC not cold on driver side - Cadillac Forum - Enthusiast forums for Cadillac Owners
Old 04-21-2011, 10:04 PM
Default AC not cold on driver side
I have a 2001 Deville, the AC on the drivers side is not blowing cold. Passenger side AC is blowing cold. I am sure it is an actuator problem. My question is how many actuators are on this car and where are they located?
Is there any good diagram I can see? Any suggestions are appreciated.
Thanks
Old 04-22-2011, 10:23 AM
there is threebut the one u r looking for is on the driver side under the kick panel close to centre console
Old 04-22-2011, 12:00 PM
I read on another forum that the one on the driver side is the mode actuator. I removed my kick panel and the part of the dash that holds the ash tray and i can see an actuator there, it is pain to get to because of the floor vent leading to the driver side. I just wasnt sure if this is the actuator causing the issue. I read that you can see the actuator moving and see if it is doing its job correctly. Can you see the actuator on this side move without taking it apart or can i physically move the actuator?
Thanks
Old 04-24-2011, 03:54 PM
u can see it move
just move the switch and watch
Heater blows hot on passenger side but cold air on drivers side wrathofdad General Tech 8 10-26-2011 07:47 PM
Cold air on driver, not on passenger. Big Jake Cadillac Seville 3 02-02-2008 10:11 PM
lower control arm driver side cadillac jones Private 'Wanted' Classifieds 0 03-24-2007 04:17 PM
Driver side door hinge bent brian321 Cadillac Deville 1 02-24-2007 03:00 PM
89 deville driver side door hinges brian321 Private 'Wanted' Classifieds 1 02-24-2007 03:52 AM
Tags
2001, ac, actuator, actuators, air, blowing, cadillac, cold, conditioning, deville, diagram, driver, located, side, vent, woring
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
