98 Deville multi-function lever issues
Hello,
My left turn signal doesn't auto cancel, the windshield washer doesn't activate, and the high beams "click" to turn them on, but don't "click" to shut them off.
Would replacing the multi-function lever resolve my issues? Also, how do I go about removing it? Hopefully I don't have to remove the steering wheel....
I would look at wiper switch. You will need to disassemble top part of column. you may have several things going on. cancelling cam spring could be broken, it mounts on turn signal switch. The wiper switch actuates dimmer. You could also see if 12v is going washer pump. Yes, steering wheel has to come off.
