98 Deville multi-function lever issues
Old 04-18-2017, 07:36 PM
forgetaboudit's Avatar
Default 98 Deville multi-function lever issues
Hello,
My left turn signal doesn't auto cancel, the windshield washer doesn't activate, and the high beams "click" to turn them on, but don't "click" to shut them off.
Would replacing the multi-function lever resolve my issues? Also, how do I go about removing it? Hopefully I don't have to remove the steering wheel....
Old 04-18-2017, 08:16 PM
I would look at wiper switch. You will need to disassemble top part of column. you may have several things going on. cancelling cam spring could be broken, it mounts on turn signal switch. The wiper switch actuates dimmer. You could also see if 12v is going washer pump. Yes, steering wheel has to come off.
Old 04-20-2017, 05:56 PM
So, now the washer functions. The left signal still doesnt cancel. I'll look into taking it apart to see what I can see. Thanks
Kik
Automatic Transmissions
11-01-2013 08:33 AM
caddymanmarc
07-27-2010 04:36 PM
jarhead
12-17-2009 07:18 PM
beddism-caddy
03-06-2009 03:07 PM
beddism-caddy
02-27-2009 09:57 AM
Quick Reply: 98 Deville multi-function lever issues
