96 Deville - Regulator and Location
Old 05-23-2007, 11:42 AM
michaeldkania's Avatar
Default 96 Deville - Regulator and Location
Is there a fuel pressure regulator that keeps the proper pressure at the fuel rail. I have heard that fuel pressure at the rail needs to be between 62 and 65 psi or the engine will not start or run properly.
Old 05-23-2007, 04:50 PM
FLCaddytech's Avatar
Default RE: Fuel Pressure Regulation - 96 Deville
48 - 55 PSI is the proper running pressue.
The fuel pressure regulator is attached to the fuel rail near cyl #7.
Old 05-23-2007, 06:12 PM
strabo40's Avatar
It is also easy to replace and the part is only about $50 at the auto parts stores. Just be sure to get the small O ring out of the seat before you place the new one in. To change it all you have to do is remove the top cover over the top of the engine. The fuel pressure regulator is to the right side of the engine. Disconnect the vacuum hose and pull the clip. Installation is the reverse.
Old 05-24-2007, 08:36 AM
Default 96 Deville - pressure regulator & location
ORIGINAL: michaeldkania
ORIGINAL: FLCaddytech
ORIGINAL: strabo40
strabo40
08-08-2012 02:55 PM
khdaniel
08-23-2010 07:19 PM
blackdevilledts
05-13-2009 07:55 AM
latinowarrior
08-19-2006 08:23 PM
transtechterry
02-24-2006 12:37 AM
Quick Reply: 96 Deville - Regulator and Location
