96 Deville - Radiator Fan Relay - Where are they
Can anyone tell me where the radiator fan relays are located. I have good readout on my dashboard indicating that the temperature sensor is OK. I checked the fuse under the hood and it is ok. I got the fans to run, but only by temporary direct connection to the battery.
My radiator fans never come on, even though I am getting up to 216 degrees at red lights and stop signs.
Mike in Wexford PA
Mike in Wexford PA
RE: 96 Deville - Radiator Fan Relay - Where are they
216 is normal and fans wont come on. Over 230 and climbing with fans not coming on isn't. Cooling fan relays are mounted on bottom of core support between cooling fans. Will cooling fans come on with a/c compressor engaged?
