96 Deville Overheats at Idle
Old 09-15-2008, 12:48 AM
Tarrance's Avatar
Default 96 Deville Overheats at Idle
96 Deville runs at about 194 to 196 degrees while driving, but overheats to over 260 degrees when at idle. Like at drive throughs and such. What could be the problem?
Old 09-15-2008, 08:24 AM
Dave S Texas's Avatar
Default RE: 96 Deville Overheats at Idle
What codes are displayed? I'd first suspect the cooling fans. At idle/very low-speed the cooling system depends on the fans, on the highway there is air-flow to remove the heat from the coolant.
Old 09-15-2008, 08:34 AM
we need more info ...
codes?
fans runnning?
mileage?
coolant maint history?
belt?
pump?
radiator?
Old 09-15-2008, 03:15 PM
Katzmans Caddy's Avatar
Coolant is not circulating at low engine speed so that points to weak water pump in my opinion.
Old 09-15-2008, 05:04 PM
Tarrance's Avatar
No Codes, I usually see steam coming from under the hood, from the water running from the overflow. I usually shut it down before it even tells me too. Afraid of damage to the engine. I was already leaning towards water pump, but drive long distances at a time and have no problem. I think my fans are running ok. I have about 144k on the Deville
Old 09-15-2008, 10:17 PM
A new pump wouldn't hurt, that's for sure! 144k....just broke-in good. Make positive sure you use the sealant tabs in the cooling system. A $2 insurance price.
Old 09-15-2008, 11:53 PM
Tarrance's Avatar
Sealant tabs? Where do I get them?
Old 09-16-2008, 08:31 AM
The sealant tabs are required for use in these engines. Any GM parts will have them: GM #3634621. Auto parts stores the sell AC-Delco will have them: #10-108 and cheaper than the GM dealer.
Old 11-05-2008, 11:56 PM
Tarrance's Avatar
Sorry Guys, looking back, I see I forgot to let you know what the culprit was. A bad relay. Replaced the relay and everything is working fine again. Seems the fans were not coming on when needed. Coming on at about 225 degrees now. Andon always when the compressor is engaged.
jamestint.com
11-30-2019 02:45 PM
mz.deville74
08-04-2013 05:46 PM
Tom45
09-03-2007 04:42 PM
redbirdT/Aws6
12-22-2004 01:31 PM
Quick Reply: 96 Deville Overheats at Idle
