96 DEVILLE - Cadillac Forum - Enthusiast forums for Cadillac Owners
Old 02-03-2006, 07:17 PM
Default 96 DEVILLE
MY DEVILLE BEGIN STALING WHEN I STOP. I HAD THE CODES READ AND CHANGED THE FOLLOWING:
EGR
IDLE AIR CONTROL
MASS AIR/MAP CENSOR
BATTERY
OIL CHANGE
SPARK PLUG
BUT THE CAR STILL STALL WHEN I STOP. TOOK IT TO A MECHANIC WHO STATED THE CAR WAS LOSING OIL PRESSURE AND MAKING THE CAR SHUT DOWN. WHAT CAN I DO ABOUT THIS TO FIX THE PROBLEM?
Old 02-05-2006, 10:17 PM
Default RE: 96 DEVILLE
you need to find out what the OIL PRESSURE should be for this car and try to get an oil pressure guge on it 40 - 60 psi but get the right information for you car and see if you have oil Pressure and if you do the you may have a bad oil pressure switch.
Old 03-01-2006, 03:43 PM
northstars do not have an oil pressure shut off....i would be looking more towards the Ignition module or crank sensors and the wiring between the 2
Tags
96, bad, cadillic, change, deville, oil, pressure, sensor, stalls, stop, transmission
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
