93 Sedan Deville, Service SSS light - Cadillac Forum - Enthusiast forums for Cadillac Owners
Old 10-06-2007, 04:05 PM
rdg rdg is offline
Default 93 Sedan Deville, Service SSS light
Hi everyone, Would anyone know why or have experienced the Service SSS Light on the dash staying on while driving?. Everything seems fine 100%. Even if there is a way to disable the light. I don't notice any problem.
Thanks alot,
Rick
Old 10-06-2007, 10:33 PM
Katzmans Caddy's Avatar
Default RE: 93 Sedan Deville, Service SSS light
One of the best links there is, I am sure you will find it helpful and interesting:
http://myweb.accessus.net/~090/toc.html#cad
Old 10-12-2007, 10:35 PM
You car has Speed Sensitive Suspension, light is turned on when module see something it doesn't like.It has flash codes, so scanners don't work.Actuator within one of struts usually stops working and sets code and turns on light.Struts where so expensive that GM stopped making them (800.00+ ea.).They determined they were not necessary for 4.5 and 4.9 (NOT NORTHSTARS)engines. They came out passive struts to replace bad struts and a tsb to make light go away. Hope it helps
Service stability system,service brake assistance,service steering and t/c light jmsnyder Cadillac STS 3 01-06-2017 12:38 PM
Service stability system,service brake assistance,service steering and t/c light jmsnyder General Tech 0 09-11-2012 11:03 PM
1992 DeVille Intermittent Service Engine/Service Vehicle Check Engine Light rzhj8s General Tech 4 04-20-2010 07:39 AM
1996 cadilac devil says (service air ride and airbag light sometimes comes on and also service eng) xpdude Cadillac Deville 1 10-24-2007 09:16 PM
GM Cadillac SUSPENSION SSS, SDD, CCR Stealth FAQ 0 07-09-2007 12:03 AM
Tags
1993, 1999, 93, 99, cadillac, codes, deville, light, manual, parts, sedan, service, sss, sts, suspension
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
