92 deville trunk wont retract. Need help.
Old 10-08-2012, 09:54 AM
Swhangin's Avatar
Default 92 deville trunk wont retract. Need help.
I searched 92 deville trunk issues, wont retract, trunk, etc. So i did search.
I am wondering if you all have any help for me.
First of all i did not slam it shut, but i did forget that it retracts on its own, so i opened it up with the key when it didnt close. I tried to pop the trunk hoping the motor would extend and it would close after that butttttt it did not. Any help would be appreciated. Thanks all.
Old 10-08-2012, 12:52 PM
Cadsforfun's Avatar
Default Trunk pull down
Does the motor have any life at all. Start by checking inline fuse, should be near motor. Does the horn work?? Check that D-switch is closed with lid up. Check for good ground,Check that hook-striker switch contacts shaft of striker assembly. If it won't release check WDO circuit breaker.Check continuity of trunk release switch.Have beer at every step of procedure.
Old 10-10-2012, 03:30 AM
Swhangin's Avatar
Thank you ill try those.
Jack West
11-12-2012 11:07 AM
sparky570
08-06-2012 08:55 PM
1989 fleetwood
10-27-2008 09:46 AM
umoms
03-03-2008 02:04 PM
DieselDemon
11-29-2006 08:57 PM
Quick Reply: 92 deville trunk wont retract. Need help.
