92 Deville stalls-has codes E12, E41, E52, E91
Old 05-05-2008, 06:52 PM
justtalkin's Avatar
Default 92 Deville stalls-has codes E12, E41, E52, E91
My 92 Deville has been giving me problems recently...I found the following codes via the digital dash: E12, E41, E52, E91. It stalls when coming to a stop, runs rough intermittently, engine surges. It is a very unpredictable condition. Some days it runs perfect. Gas mileage increasesand gives the impression that everything is normal and fine. Then out of the blue, it acts up again. Mileage falls off, engine runs rough, etc..... I've changed dist cap, rotor, plugs, and wires--made some difference. I'm ready to change the fuel filter and clean out the throttle body. I am hoping the codes are a good clue. Can someone give the tell-tale diagnosis from the codes? Thanks in advance for your advice.
Old 05-06-2008, 11:23 PM
Katzmans Caddy's Avatar
Default RE: 92 Deville stalls-has codes E12, E41, E52, E91
12 - no distributor signal
41 - no camshaft position sensor signal from ignition control module
52 - PCM keep alive memory reset
91 - PRNDL switch or transmission range switch signal problems
12 and 41 are the problem ones for your condition.
Old 05-23-2008, 10:30 PM
justtalkin's Avatar
Thanks for the info. I am still limping along....in spite of the trouble codes. Is all this pointing to a defective Ignition Control Module? For as long as I have had the car, almost 5 years, the ICM has never been replaced. Thanks for your added support.
justtalkin
Tommygun8
09-11-2011 11:35 AM
banderson
09-04-2009 08:45 PM
jaymit
08-08-2008 05:31 PM
jemlrdb
11-04-2006 11:31 PM
handana
06-30-2006 12:37 AM
Quick Reply: 92 Deville stalls-has codes E12, E41, E52, E91
