85 sedan deville error code E26 and F11 and F48 - Cadillac Forum - Enthusiast forums for Cadillac Owners
Old 02-16-2009, 09:41 PM
Default 85 sedan deville error code E26 and F11 and F48
85 sedan deville error code E26 and F11 and F48. How can I get these codes to go away? Plus the service now light comes on until I give it a little gas.
Thanks for any advice,
Jason
Old 02-18-2009, 11:08 AM
Get a factory service manual to trace and diagnose each code to repair the cause. You can disconnect the battery to erase any that are history codes, but until the reason is repaired, codes will come back.
Old 02-20-2009, 11:39 PM
Katzmans Caddy's Avatar
Default Your codes are as follows:
E26 - Shorted Throttle Switch Circuit
F11 A/C High Side Temperature Circuit Problem
F48 Very Low A/C Refrigerant Pressure Condition
I always suggest when a car is this age to note the codes and erase. Code E26 for example indicates a short condition which may or may not be a continuing problem. If you have a persistent code it should be attended to. The AC codes are obvious, you have a leak.
I also suggest making sure your gas cap is properly sealing, #1 cause of check engine light.
Old 02-21-2009, 08:36 PM
In earlier post you stated you scored FSM, have you got it yet?
Error code P0171 and P0174 ranjit Cadillac Seville 0 10-13-2012 12:10 PM
85 sedan deville E22 error code THECLAW Cadillac Deville 4 02-12-2009 11:45 PM
TCS Error Code Afterburn Cadillac Seville 0 04-29-2007 03:03 AM
error code E30 need help brick Cadillac Deville 5 03-06-2007 12:08 AM
error code e28 e67 brick Cadillac Deville 1 03-01-2007 12:21 PM
Tags
1984, 1991, 91, caddy, cadillac, check, code, codes, deville, e26, engine, error, f11, f48, problem, refrigerant, system
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
