2002 deville pull codes?????Help
Old 03-16-2009, 07:45 PM
kathygill12's Avatar
Default 2002 deville pull codes?????Help
I hve seen the threads on codes.
It says to use off/amp and warm (red button)
the 02 deville has only the on/off and no warm button only a dial.
What do you press to pull codes on the 02 deville?
Thanks in advance
Car is running rough and sometimes stalls.
I have had autozone pull the codes and they gave me a cluster of paperwork. I want to clear the codes and pull them when the car dies out again.
thanks again
Old 03-18-2009, 09:17 AM
92_Daddylac's Avatar
To enter diagnostic mode, proceed as follows:
  1. Turn ignition "ON." Engine can be either OFF or RUNNING.
  2. Depress the "ON/OFF" button and the "UP ARROW" end of the info button on the driver information center simultaneously for a few seconds.
All the dashboard lights will illuminate, including the segments of the DIC display. You are then presented with text. You can cycle through different questions using the UP and DOWN arrows on the info button. If you select "ALL CODES" this will give you all the codes. For example (PCM P0115 HISTORY) THen lets say this is also a current problem is will state this after showing the history code (PCM P0115 CURRENT). These are the abreviations that you should see when scrolling through the choices. You can select each one and check for codes as well.
  • ABS -- Antilock Brake System
  • AMP -- Amplifier
  • DDM -- Drivers Door Module
  • DDS -- Drivers Door Switch
  • DIM -- Dash Integration Module
  • IPC -- Instrument Panel Cluster
  • IPM -- Instrument Panel Integration Module
  • IRC -- Integrated Radio Chassis
  • LRD -- Left Rear Door Module
  • MSM -- Memory Seat Module
  • PCM -- Powertrain Control Module
  • PDM -- Passenger Door Module
  • RCC -- Rear Climate Control
  • RFA -- Remote Function Actuation
  • RIM -- Rear Integration Module
  • RRD -- Right Rear Door Module
  • RSS -- Road Sensing Suspension
  • SDM -- Inflatable Restraint Sensing and Diagnostic Module
  • TTM -- Tilt and Telescopic Steering Wheel Module
  • VTD -- Vehicle Theft Deterent
try this and see what you come up with.
11-17-2017 07:16 PM
michael152354
06-29-2011 08:04 PM
rafael nazario
03-06-2008 04:11 AM
bighank
11-22-2007 09:14 AM
Torrence
07-26-2006 07:28 AM
Quick Reply: 2002 deville pull codes?????Help
