2003 Brake shimmy
2003 Brake shimmy
Ok,,Brakes on my 03 Deville shimmy on slowing down. I replaced pads and rotors(had 81,000 miles on them). Still did it. Had tires balanced. Was not as bad but still does it on slowing down. Are bushings bad or what? Bought the car used,no car fax damage reported. Drove fine untill 3 -4 months ago.These should be smooth on braking.
RE: 2003 Brake shimmy
i know you said that you replaced the rotors .. but going by what has been reported,
something is wrong back there in the rotor dept. maybe new rotors were warped or
got warped?
IF it is pulsating or shimmy, it has to be caused by a rotating component. no?
got warped?
