2001 Cadillac DTS - Is it possible to raise or remove the SPEED LIMITER on a 2001 Caddy DTS?
Old 09-24-2007, 12:28 AM
DTS_BOI's Avatar
Default 2001 Cadillac DTS - Is it possible to raise or remove the SPEED LIMITER on a 2001 Caddy DTS?
Hello again...
Is it possible to raise or remove the speed limiter on my 2001 DTS? The computer shuts it down at 130 mph, but I have heard that Northstars can hit up to 150 mph. Can anyone help me out?
Moderator edit
Title
Old 09-24-2007, 06:33 AM
Katzmans Caddy's Avatar
Default RE: Is it possible to raise or remove the SPEED LIMITER on a 2001 Caddy DTS?
Your car is limited to 130 because of your tires, speed rated H. It is possible to change the speed limiter but without V rated tires you would kill yourself and possibly others, so I'm not going to tell you.
Old 09-24-2007, 08:12 AM
DTS_BOI's Avatar
I purchased my Caddy with vogue tires, but it now has Z-Rated Dunlop SP Sport tires installed. These tires are standard equipment on my Mercedes and I was so impressed with the wet weather handling that I put a set on my Caddy.
I know my new tires are rated higher than 130 mph... Can you please tell me?! Anyone???
Old 09-24-2007, 09:35 AM
^ i'm not sure there's much you can do without a chip. on my acura, however, although the speed governor comes from the factory set to 140mph, i've been faster than that! oem ecu's are tricky things these days
Old 12-02-2007, 11:25 AM
ORIGINAL: Katzmans Caddy
I love it ....
Sorry guys, cant give you advice that makes one dangerous.
Old 12-02-2007, 03:14 PM
G.A.R.Y.'s Avatar
ORIGINAL: Stealth
I love it ....
Well the guy said he now has "z" rated tires. Can the limiter be changed?
Old 12-02-2007, 03:49 PM
Speed limiter can be raised, you just have to good reason. So unless your law enforcement it's not going to happen. If you are there is alot of red tape involved.
Old 05-30-2018, 06:44 PM
Amsterdutch's Avatar
I have my Cadillac limited to 90 mph due to someone before me putting non-air shocks on my 2001 Cadillac Deville DTS ...how can I fix this it's very annoying ???? Please help?
Old 10-06-2020, 08:43 AM
Lawrence Wilson's Avatar
Exclamation
I have a 2005 SRX and I can't seem to find the speed limiter fuse does anyone know where that is?
Old 10-20-2020, 03:15 PM
sonjaab's Avatar
Many PCM burn/tuners out there to wake up your N-star and raise up your speed limiter.
A search will help you.
Again heed the warning on speed rated tires! (I know u have them).
08-03-2013 01:52 AM
00DTSteve
02-10-2009 07:35 PM
fac203
03-12-2008 07:01 PM
dewey1447
02-10-2007 12:13 AM
infj23
12-16-2006 08:37 PM
Quick Reply: 2001 Cadillac DTS - Is it possible to raise or remove the SPEED LIMITER on a 2001 Caddy DTS?
