1996 Cadillac DeVille Concours - Hard to shift between gears
Old 12-02-2007, 12:13 PM
96concours's Avatar
Default 1996 Cadillac DeVille Concours - Hard to shift between gears
My 96 Councours will shift, but it is really stiff. I mean to the point thatI think if I am not ginger with it, it might break the shift lever. Has anyone else had a problem like this? I am thinking a bent linkage or something.
Preston
moderator edit
title
Old 12-02-2007, 12:48 PM
ORIGINAL: 96concours
Preston
i am not understanding .. it is an automatic, right?
i would not want to guess wrong ...
Old 12-02-2007, 03:54 PM
Default RE: 1996 Cadillac DeVille Concours - Hard to shift between gears
It sounds like you may need shifter cable. If it binds bad enough you can break steering column.
Old 12-02-2007, 07:50 PM
96concours's Avatar
Yes it is an auto on the column. What I mean is from park to any gear, it is extremely difficult to shift, like something is in a bindand yes I am scared of breaking the column.
Old 12-09-2007, 09:46 AM
there is a pivot bolt on the column that starts to bind over time.you may be able to lower the column and spray with wd40 and work back and fort untill it frees up. or remove the bolt,cleani it apply greas and reinstall. it takes a allen head to remove
Dana Dunagan
Automatic Transmissions
11-24-2014 09:43 PM
jpmr315
10-08-2008 03:48 PM
96concours
12-29-2007 05:46 PM
michaeldkania
03-16-2007 04:52 PM
Quick Reply: 1996 Cadillac DeVille Concours - Hard to shift between gears
