01 Deville - Bad Rear Wheel Speed Sensor
Old 11-17-2008, 06:52 AM
kb6565's Avatar
Default 01 Deville - Bad Rear Wheel Speed Sensor
DTC Code: C1235 - Right Rear Wheel Speed Circuit Open or Shorted
In researching my problem, I have read in 2 different forums that the whole wheel bearing hub assembly ($112.79 ) has to be replaced. In another, I have read that the sensor itself can be replaced and is available from RockAuto (AIRTEX Part # 5S4644 - $34.79).Can someone tell me definitivelywhich is correct. Could this just be a bad connection?
[IMG]local://upfiles/7042/C1C41AA523E24663B1EBEE61666692DF.jpg[/IMG]
Old 11-17-2008, 06:05 PM
carnut's Avatar
Default RE: 01 Deville - Bad Rear Wheel Speed Sensor
The code tells you to check the harness for being unplugged ( open) or rubbed thru on a suspension component ( shorted) Would have more clues if you had just pulled the wheel and checked the harness to the sensor prior to posting. Right rear is passenger side rear.
65lowdeville
Automatic Transmissions
10-23-2013 10:00 PM
BB2nite
08-17-2011 08:41 PM
astrodan13
Aluminum Block V8s
06-14-2011 12:24 AM
03-03-2008 10:14 PM
wrtnova
07-23-2007 02:37 PM
Quick Reply: 01 Deville - Bad Rear Wheel Speed Sensor
