where to get abs pump assy 19244856
Old 03-31-2017, 03:52 PM
donaldhetzler's Avatar
Default where to get abs pump assy 19244856
anyone have a lead on where to get the abs pump assy for a 2004 cts with the 3.6? or a rebuilder, remanufacturer, any angle that might save me money. according to the dealer, mine is bad and leaked a bunch of brake fluid into my ebcm module, causing it all to flip out. i'm going to check to see if there were any recalls or service bulletins, also. thanks in advance.
Old 04-01-2017, 09:33 AM
If there was a recall or special policy dealer would repaired/replaced under warranty. I don't believe there is one on ABS. The "thriftiest" route would be a "Pick N Pull" style salvage yard. Since you remove it you get and idea how to install it. Be sure to check condition of connector.
99STSGUY
Aluminum Block V8s
07-07-2010 06:52 PM
jono6406
02-13-2008 12:13 PM
jono6406
Vehicular Projects
01-26-2008 08:22 PM
tpcook
12-13-2007 04:43 PM
gkmoz
04-23-2006 11:23 PM
Quick Reply: where to get abs pump assy 19244856
