Rear Axle Pinion seal
hello nbrbc
hello nbrbc ,i am from shanghai china!you own a workshop or you work in a cadillac dealer? can you talk something about your workshop or give me some photos about it ?i am very interesting in your workshop! i am working in the first cadillac dealership of china ,and i want to get some advise from you about business secret!
thank you !
thank you !
RE: Rear Axle Pinion seal
I have a 2006 Pontiac Solstice, which uses the same differential.
We have a VERY serious problem with pinion seal leaks, perhaps as many as 10% of the total produced, which would be around 2000 with leaks.
Many of our owners also have a whine coming from the rear differential. GM has replaced some of the rear carriers, which usually takes care of the problem. One of our owners is on his third carrier already, and yep, the whine has returned AGAIN!
We were told that the CTS was experiencing similar problems. But this forum has only two people posting about it????
I have a 2003 cts with a pretty healthy leak coming from the left rear axle seal and also a leak coming from the transmission where the shift link connects. the repair is 1300 for both peices of rubber not including labor.
