rattling/clunking noise on CTS
I have a 2005 CTS with just over 36,000 miles, I am noticing a clunking or rattling noise on the passenger side of the vehicle, I haven't been able to pinpoint it to the rear or front but we hear it pretty much all the time especially at low speed over speed bumps and slight bumps in the road. Some days it seems louder than on other days and it doesn't seem to have anything to do with the outside temps. Does anyone have any info on this? We have had it at the shop once, and they replaced both front sway bar links because they found some slack in the joints, but the rattling/clunking noise persists. Could it be the struts? Thanks!
RE: rattling/clunking noise on CTS
Send it to the dealer and tell/show them what car is doing and ask them to fix it. You can't tell them how to fix it, you can ask them to make noise go away.
I did that when I took it to the dealer after I noticed the noise, had someone ride with me but the noise wasn't very noticeable at that particular time. I'll have to take it back to them and hopefully it will be making the noise when i do, just thought someone may have had this problem and could inform as to what it ended up being.
Noises unfortunately can have a multitude of causes, shocks or mounts, lower control arms, or possibly something else. try to notice anything and everything you can related to how to reproduce noise. and feed it to the tech so he will be able to verify it is fixed when he is done. Get rental on drop off and tell your adviser you want to road test car prior to pick up to be sure it is fixed so maybe they make sure it's fixed.
I had the exact same issue on my brand new 2008 CTS. I was more like a thumping noise every time (but delayed a few milliseconds)I went thru a bump or big crackat low speed. I took to back to the dealer twice, and finally on the last trip, one of the guys threre discovered do***ent ID: 2152631, #PIC4838A - Clunk Noise in Rear Suspension Over Bumps - Keywords knock pop popping - (Jun 12, 2008). Essentially, it said to check the shock absorber in the rear suspension knuckie on both sides. Inspect for contact between the shock clevis bracket and the knuckie. If the bushing is de-bonded, contact can occur causing a noise. If the bushing is de-bonded, replace the knuckie, but do not replace the lower control arm, the cradle, the shock, or any other suspension link.
I never really knew what they made by "de-bonded", I wish I had seen it... But at any rate, that indeed was the problem. Good luck!
MBC Racing
06-15-2011 02:39 PM
jsumney
02-14-2011 12:35 PM
