Oil cooler lines.
Old 05-21-2015, 09:45 PM
nnedrebo's Avatar
Default Oil cooler lines.
Just had a question on the oil cooler lines that go to the bottom of the radiator. I was curious about how much pressure those line have in them? I bought a 03 cts and the guy had done some work to it and pulled the line out of the radiator on the passenger side of the radiator and it started to leak and then i took apart the other side and those line had been "repaired" using like jb weld or something so I think I may have to cut it at the rubber end and put it on the new one with a clamp. So just curiouse on the pressure in the line wether or not a clamp would be ok on it
Old 09-13-2015, 07:40 AM
Fatties's Avatar
Banned
I guess this is a normal kind of happening and most of the times through the kind of things that are happening. Originally it can all be growing in it.
greg2169
01-28-2013 04:07 PM
Need4Camaro
08-03-2011 08:14 PM
langeberg
04-29-2008 04:21 PM
pkared
Aluminum Block V8s
05-30-2007 03:35 PM
Quick Reply: Oil cooler lines.
