Help needed
Help needed
I have a 2003 CTS.
Few days ago i went to start it and the engine would not crank.
Complete silence.
All dash lights worked, headlights worked and did not dim when i attempted to start the car.
I checked the following:
Codes. Non popped up other that front window codes.
Checked starter relay (swapped with blower relay) no luck
Checked battery: 12.5 volts
Checked connection to ECU.
When i insert the key in the security with lock light goes out after a few seconds.
-could it be the chip is faulty or de-programmed?
I am running out of options
The car does not crank or click. I turn the key to start and all goes silent.
any thoughts?
Complete silence.
any thoughts?
10-24-2007 04:57 PM
