condensation on oil cap? 03 3.2 cts
on my 03 CTS 3.2, Itseems to have an unusual amout of condensation build up on the oil cap and the top of the oil fill pipe ...Looks like yellow muck.Has anyone else exp this? and why does it happen.I clean it out everytime I change the oil
RE: condensation on oil cap? 03 3.2 cts
I have seen it on my 03 cts. If I have the same muck as you thenit could be that this yellow muck is actually early signs of engine sludge and you should look into possible treatments before you lose horse power and throttle response as I was told. I know that castrol makes an oil that is supposed to stop the build up of engine sludge but I am not aware of any other products through mobil 1 or any other brands.
GM has done tests in cold country of engines that do not come to temperature.
they have found that some engine will almost double the volume of fluid in the
crankcase due to ac***ulating moisture over the period of oil changes.
that means WATER and OIL.
it does take quite a few miles of driving to rid of the moisture at every engine start.
in SoCA, it takes me over 5 miles of driving to get my engine and trani to full temp,
my D.I.C. provides that info. when i was in NY, it was a much longer period.
i'm not familiar with your car, but is there a way to have the system report the temp
of oil, coolant and trani?
ORIGINAL: lavarok
hey, thanks for your input, to my knowledge,I do not have the ability to find outwhat the specific temps are with the engine of my 03 3.2 cts. If anyone else has info, please let me know... thanks so much for the info on this subject......
one last thing, found what i was referencing to above.
go here:
https://www.cadillacforum.com/m_5792...1/key_/tm.htm#
a partial quote
go here:
a partial quote
the oil was due to be changed due to short tripping the car, time since the last change and the oil is likely never getting to operating temperature due to the short trip driving. Many people don't realize that the worst possible thing to do to engine oil is to short trip the car. I've seen the oil life monitor "timeout" in as little as 500 miles in winter , short trip driving. The oil sampled from that test sequence had over 35% gasoline in it due to the fact that the engine had been started so many times and had never been warmed up ...!!! In winter driving like that you can actually see the oil level in the crankcase go UP as gasoline and water ac***ulate in the crank case. One long drive on the expressway to warm up the oil good will restore the oil and the oil life can/will compensate for this. On the other hand, repeated, long trip driving will often go 7500 miles on an oil change according to the oil life monitor. In any case, one year is the maximum I would ever recommend to wait for an oil change , especially in occasional use type cars.
ORIGINAL: lavarok
Yogi
11-21-2007 10:58 PM
