Bad Rattle
Old 09-26-2006, 10:17 AM
bill tell's Avatar
Default Bad Rattle
My 06 CTS has a bad rattle in the back rear passenger side area. It has been in the shop twice already and they can't seem to find the issue. It only happens on rough roads and and around 30 miles an hour. It sounds like some thing is loose and plastic. Help
Old 12-14-2006, 03:12 AM
Default RE: Bad Rattle
Have your tech check the hinges on the trunk. My V had a rattle like the one you're talking about. It was the in the front, though. Turned out to be the left hood hinge...after the dash was torn apart.
Old 12-15-2006, 06:29 PM
It could be your Rear clip bumper cover vibrating against the rear right quarter panel make sure that there is no space betweek them and that your clip is fully tightened and against the quarter where they meet.
Old 09-21-2009, 10:32 AM
clownmagician's Avatar
Default Mine Too
Is the rattle coming from inside just back corner over the side window area. My car has been in 5 times (also in the shop today) for the rattle.
Old 09-21-2009, 04:29 PM
take out the back seat and see of the rattle goes away .. if not, have someone else drive and you ride there with no seat .. hopefully, you will find the guilty part.
Old 09-22-2009, 07:00 AM
Default Keep looking
My dealer seems to think the rattle is coming from the seam in the roof and pillar line. He has photos of the spot and next week will try and fix it. I have had my entire rear section (of my car) removed and put back with insulation. The rear seats have nothing to do with the rattle.
astrodan13
Aluminum Block V8s
06-14-2011 12:24 AM
Eddiek
03-10-2009 04:45 AM
03-03-2008 10:14 PM
Eddiek
01-13-2006 04:29 PM
Real Cad
07-12-2005 12:48 PM
Quick Reply: Bad Rattle
