2003. Cts
Old 02-01-2010, 11:48 AM
zaczg's Avatar
Default 2003. Cts
Hi guys,
considering to buy a CTS model from 2003. So as I am in europe, and this is exotic for us, i would appreciate some info from you.
What is service intervals, and is it good for maintenance?
What engine is most reliable?
Stuff like that
thank you
Old 02-04-2010, 10:35 AM
2000Falcon's Avatar
I've got a 2003 with the 3.2L engine. Here's a list of what i've done to it so far. The car has 130K KM on it.
- Thermostat
- Diff seals
- Crank Position sensor
- brakes (wear & tear)
- Drivers side rear wheel bearing
- Shocks (wear & tear)
- Trunk lid shock arms
That's pretty much all of it that I can think of. One of the engines (not sure if it's the 2.8 or 3.6) has been having timing chain failures. I don't think these were even an option in 03'. I could be wrong though.
Good luck with the car, I absolutely love mine. I really want a new one
Regards,
Ross.
Old 12-28-2012, 12:33 PM
Kik's Avatar
Kik
Kik is offline
With 130,000mi on your 3.2L you're living on borrowed time for the timing belt, I believe they are suppose to be changed out at around 80,000 miles, If it snaps then you'll probably have a huge paper weight on your hands. Also at 130,000 you'd probably be just a well to have the water pump and tensioners changed also...As long as they're in there.
pramim
03-07-2012 10:21 PM
RM25Y1
08-10-2007 03:35 PM
jchutch
07-17-2006 11:37 AM
madsyd24
06-28-2006 03:51 PM
mastopietro
03-09-2006 10:41 AM
Quick Reply: 2003. Cts
