What could be causing these problems and how to fix it?
I own a 1990 Cadillac Coup Deville with 89000 miles on it. Every time I turn on my car, the radio and clock restart itself, so the clock is at 1:00 and the station is 1400 am. The button to open my gas door is also not working, so I cannot open my gas door to get gas. I need help ASAP!!!! I need to get gas hahaha!
What could be causing these problems and how do I fix them?
You have two separate issues most likely unless the gas lid release and radio memory are on the same circuit (power with key off)
I would start by having your battery load tested.
always check body and engine ground cables. There are several.
If battery voltage drops below 10 volts while cranking you will lose memory power for the radio.
If you lose radio memory when you hit the gas lid button then your getting close.
Fords did this also during the 80s into the 90s.
meehow01
03-20-2017 06:03 PM
Dutch Eddie
Automatic Transmissions
07-10-2012 06:47 AM
GARDHINOJOS
11-06-2007 08:41 PM
