allante ABS doesn work - Cadillac Forum - Enthusiast forums for Cadillac Owners
LinkBack Thread Tools Search this Thread
Old 04-14-2009, 10:36 AM
Default allante ABS doesn work
ABS doesn work? park it and do not drive it until it is fixed. These brakes are not to be messed with.
The response by moose is out of ignorance. An Allante w/o ABS is basically a car with 3 or 4 stops away from a total failure.
PARK IT ...
Quote:
car_collector
I'm a long time car collector that just could not pass up a nice running 1987 Allante. But there are a few issues that I can use some help with. The power steering is at times hard to turn.( Like the power part comes and goes)The belt is new and the P/S fluid is fine. Does that mean the pump is bad? The ABS doesn't work. Is it o.k to drive without it? and last the DIC display shows just a rear light is out, Does that mean as the owners manual states that the every thing else is working as it should? The value that these cars offer in teams of looks and options is many,mant times what the purchase price is Thanks for any help
Quote:
moose
Sorry I can't answer it all, but here is what I know. The brakes will work without the ABS function. You simply won't have the stopping benefits of the ABS. As far as the lights, you will probably find that there is one light out. There is a redundancy built into the system. Make sure you use the correct bulb. It should be a 2057 with a brass base. I purchased them at NAPA. The 1157 bulb which people often install can cause overheating and melting of the socket and lens. This is a very expensive repair/replacement. I can't say what the deal with the PS pump is. Good luck.
Heat doesn't work on 07 Escalade? ATrain General Tech 1 12-14-2012 01:24 PM
Drivers heated seat doesn't work special k Cadillac CTS 2 03-03-2011 04:51 PM
2007 SRX radio antenna schematic - AM doesn't work JTM000 General Tech 0 10-11-2010 05:49 PM
My HVAC unit on '03 Cadillac Escalade EXT doesn't work. What can be the problem? redsoxnation5 Cadillac EXT 2 01-12-2009 10:28 AM
Help...turn/brake light doesn't work with headlights on meyer13 General Tech 3 09-15-2007 08:30 PM
Tags
1987, 1992, abs, allante, cadillac, drive, fluid, power, problems, pump, running, safe, steering, system, working
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
