Go Back   Cadillac Forum - Enthusiast forums for Cadillac Owners > General Technical Section > Braking System
Sign in using an external account
Register Forgot Password?
Search
LinkBack Thread Tools Search this Thread
Old 11-05-2008, 03:45 PM
Default Rear brake Caliper issue, 95 Deville
I bought a 95 Cadillac Deville this past year from a friend. When I got the car I replaced the front brake pads right away. No problem, similar to other Chevy brakes with the 2 Allen wrench bolts to loosen.
Today I pulled the rear tire to replace the back pads as they've started to squeal. The lower caliper bolt is just a simple hex head, cake. The upper, I have no idea how to loosen it. It seems to have a rubber plug of some sort inserted into the middle and I have pulled on it as hard as I dare trying to pop it out without tearing it. I can't tell if it is an Allen wrench socket that is plugged or what. I see no other possible way to loosen the bolt. Anyone have any idea on this specific vehicle what more I have to do to get the caliper off?
__________________
1995 Cadillac Deville
Old 11-05-2008, 03:53 PM
Default RE: Rear brake Caliper issue, 95 Deville
Did you try to lightly tap the caliper loose.On my 99 seville you remove the lower caliper bolt and it swings upward on the upper caliper bolt. Sometie it takes some extra help to loosen the caliper.try to blled the line first then tap it upward. Once the caliper swings upward you can slide the top off the hinge.
Old 11-06-2008, 01:16 PM
Very nice, thanks Sneak, I'll be tryin this later today. Seems likely that this is what I'm lookin at as talking to a buddy he suggested the possibilityof a slide-type upper bolt too.
__________________
Old 11-06-2008, 05:40 PM
Hey, another question, same job >_<. It was just a simple swing which is cool. Easier imo then the usual double bolt. I had to drop the Sway Control bar to get it to swing far enough to get the old pads out, now here I ran into another issue.
I have one of those simple manual crank tools to compress the caliper piston. Flat plate, screw rod passing through it with a handle on one side and small plate to push the piston on the other. . . I cannot, for the life of me, turn it hard enough to compress the piston where I need it to get the new in. I'm not a weak guy so I don't think it's just a matter of me failing. I took the cap off my brake reservoir to try and relieve as much pressure as possible, but still no luck. Any special tools or perhaps a pressure release valve of some sort?
__________________
Old 11-06-2008, 06:40 PM
Katzmans Caddy's Avatar
Special tool yes but a pair of needle nose can do it. You need to thread the piston into the bore. There are cutouts in the face of the pistion to turn it into the bore.
__________________
2006 DTS Performance - L37 32v Northstar NHP V8 292 HP - 1 of 1
1999 STS - L37 32v Northstar V8 300 HP
1998 Deville D'Elegance - LD8 32v Northstar V8 (Sold July 9, 2011 with 225,000 km)
1993 Fleetwood - L05 5.7 TBI V8 (Sold July 18, 2012 with 308,000 km)
1999 GMC Suburban SLT- 5.7 Vortec
1998 Olds 88 LS - Series II 3.8 V6
1973 Pontiac LeMans GT - 454 V8 1 of less than 5
Tags
95, brake, cadillac, cadilliac, caliper, calipers, calliper, change, compression, deville, head, hex, rear, remove, socket
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
