very hard shifts
very hard shifts
04DTS here with 38k. Never abused. Get in it the other day, and its shifting like it has a B&M shift kit in it! All four gears were slamming in, even when slowly accellerating. I turned around, went home, shut it off. started back up, checked trans fluid=running in park=normal. Took it back out, and back to normal[sm=wtf.gif] I dont get it?
No Check Engine
Checked history codes and found: P0731 and B0429
Anyone else seen this? Am I in for a unpleasant surprise?
No Check Engine
RE: very hard shifts
ORIGINAL: 04dts
No Check Engine
No Check Engine
P0731 = First gear incorrect ratio, sensor may be failing
Diagnostic Aids for P0731
Inquire about overloading the vehicle, exceeding the trailer-towing limit, or towing in Overdrive.
Inspect for intermittent automatic transmission input (shaft) speed sensor circuit conditions.
Inspect for intermittent vehicle speed sensor circuit conditions.
Inspect for an incorrect calibration.
North49
Automatic Transmissions
07-08-2010 11:28 PM
