p0730 from trans swap
Old 01-21-2009, 10:09 AM
jimnet518's Avatar
Default p0730 from trans swap
I have a 97 deville that had a bad tranny soI swapped a 95 eldorado transmission into it, now I am getting a code P0730, incorrect gear ratio, I looked them up and it appears that the only difference is the final drive ratio is 3.71 and it is supposed to be 3.11, is there any way to fix this? do i have to change a part in the transmission or can i just modify the computer to run with this newer ratio, i know that the concours uses this ratio
Old 01-21-2009, 01:40 PM
jimnet518's Avatar
Default RE: p0730 from trans swap
after much searching i have found that it may be possible to flash the pcm with the newer gear ratio
stealtreasure
03-10-2016 02:37 PM
frenum49
10-16-2008 09:49 AM
Cadman
10-03-2006 10:20 PM
parkervess
10-01-2005 07:21 PM
nizmosis
09-26-2005 10:26 PM
Quick Reply: p0730 from trans swap
