having ploblem 1999 catera transmission
Old 09-13-2007, 10:30 AM
amadelta's Avatar
Default having ploblem 1999 catera transmission
Hi guy, im new here, i was woundering if some one could help me with some problems im having with my 1999 catera, my early transmission warning light appear when i drive for a long distance. I would like to know if some boby could give me some tip how to fix it.
thank you
Old 09-13-2007, 10:34 AM
amadelta's Avatar
Default RE: having ploblem 1999 catera transmission
hi, im having problem with my 1999 catera, the early transmission warning ligth appear when i drive for a longo distance i would like to know if someone have some tips how to fix this problem
thank you
Old 09-13-2007, 11:31 AM
amadelta.... have you checked the trans fluid???? that would be a good start. how many miles on the Catera?..... have you owned it sense new? have you had the trans fluid changed, and tuned?........... also WELCOME to the FORUM!!!! keep the FORUM posted..... i'm sure a Tech will respond also.........
Old 04-03-2008, 09:41 PM
Amadelta, have you found any solution to the transmission light? It also happens on my '99 Catera when i drive more than 20 miles. I've not had anything done to it yet. Please let me know if you have fixed the problem.
If there's anyone out there who can help me solve this problem, please let me know.
thanks.
jikoto
Old 04-05-2008, 04:08 AM
hi guy;im new memeber, im worried if some one could helpe me. my 98 catera speed change only one time from 1 to 4 or 5 i mean it did not change step by step and the transmission warning ligth appearthanks
Old 04-05-2008, 04:28 AM
hy guy;my 98 catera speedalways jumps from 1 to 4 or5 speed and the transmission warning ligth appear. i have changed tcm and the transmission unit i mean the gear boss. still the same problem. now im about to change the ecm. please can you advice me? thanks
Cadillac-Catera
07-18-2022 12:40 AM
A1AutoSales
10-18-2012 12:18 PM
Chaotic94
01-16-2011 06:58 PM
sgeorge
Automatic Transmissions
09-30-2008 08:15 AM
warnerwh
04-21-2007 03:49 AM
Quick Reply: having ploblem 1999 catera transmission
