gearbox conversion TH350 to TH200-4R
Old 03-19-2009, 10:51 AM
ALPAq's Avatar
Default gearbox conversion TH350 to TH200-4R
Hello everyone.
I asked about it but have not received a response. I think the appropriate place for this question.
If the TH350 gearbox fit into my engine (350cu Oldsmobile) , the gearbox TH200-R4 (or TH200) will also fit into it without making changes? And vice versa, if my gearbox TH350 will fit without modifications to the engine Oldsmobile 307cu (1985) from which is the gearbox TH200-4R?
Thanks
Regards
Old 03-19-2009, 09:04 PM
Your 83 DeVille would have come with 200r4. Re-installing it is not a big deal. You should be able to get driveshaft from 86 Fleetwood. You will need wiring kit for TCC to operate without ecm.
Old 03-20-2009, 03:53 AM
ALPAq's Avatar
Thank you
Come not fully understand about the wiring.
So the board can not simply install the engine 307 instead of 350 to my TH350 and ride? Without any changes?
jono6406
01-28-2020 08:48 AM
fe427avanti
12-29-2007 03:50 PM
miami79
02-06-2006 10:10 PM
67SEDANDEVILLE
07-07-2005 09:46 PM
67SEDANDEVILLE
07-07-2005 08:03 PM
Quick Reply: gearbox conversion TH350 to TH200-4R
