the foxpaw, not-inmortal 4T80-E transmission ...
Old 09-17-2007, 03:43 PM
Default the foxpaw, not-inmortal 4T80-E transmission ...
foxpaws
I went to get the fluids changed out of my car when I bought it they said not to do the tranny fluid - at the dealership - they did the rest of them (coolant, brake) but not the transmission - should I go ahead and have them do it anyway?
I am pretty sure I have the old bullet proof 4T80-E in my '93
as i understand, dealers FLUSH ...
if you click on #2 of this
https://www.cadillacforum.com/m_6733/tm.htm
then go to the 2nd page
you will find this
https://www.cadillacforum.com/m_6036/tm.htm
Old 09-18-2007, 10:54 AM
foxpaws's Avatar
Default RE: the foxpaw, not-inmortal 4T80-E transmission ...
Hey, I did the coolant, with no flush - and the brake fluid - when I got the car, I was just wondering about the tranny fluid they didn't change out - so I guess that is a yes on changing out the transmission fluid at 60,000?
Old 09-18-2007, 11:37 AM
ORIGINAL: foxpaws
IF I was calling upon my wheels to do 100+ mph, or even just a few 6 sec runs, I be doing it even more often.
My harsh driving habits have me at around 25,000 .. cheap maint .. trani O.H. is what? $1,500 to $3,000 ?
Quick 30 min job, that i hear even a girl can do .. ohhh, forget it .. broken bits of nails are not friendly to gears.
Allantes take a bit longer since they are so damn low, i cant drive mine onto my ramps .. jacks only..
There is this practice that if one runs to the performance limits of a car, any car (at the track of course), BOTH engine oil AND trani fluids should be changed the following day. Some extend that to the POSI-traction gears and the transfer case gears when you have those (4x4).
There is nothing like silky clean fluid and new filters to extend the life of such a workhorse as a trani. IMHO.
The links were meant to address the Flush vs DRAIN.
Some cars (which I got) allow you to disconnect the line to the TRANI OIL COOLER (your '93 has none of that) and literaly pump/DRAIN much more than dropping the pan. However, your 4x4, may have one .. may.
the trani is bullet proof, the $40 plastic solenoids that shift it for you at the command of the computers .. NOT !
mike rickard
Automatic Transmissions
04-14-2009 09:15 AM
JackV
11-05-2008 01:09 AM
jpmr315
10-08-2008 03:48 PM
thaghost87
06-26-2008 07:15 AM
runwithaknife
12-18-2007 08:26 PM
Quick Reply: the foxpaw, not-inmortal 4T80-E transmission ...
