Do I Need A New Overdrive or Transmission?
Old 09-17-2007, 10:01 PM
CadillacGirly's Avatar
Default Do I Need A New Overdrive or Transmission?
My 1994 Cadillac Seville SLS won't shift into it's final gear. It almost sounds as if it "red-lines" (the sound you hear when you don't shift in a manual transmission). Could this be the overdrive or is it the transmission?
[sm=helpout.gif]
Old 09-17-2007, 11:23 PM
Katzmans Caddy's Avatar
Default RE: Do I Need A New Overdrive or Transmission?
Check the fluid level and condition first. Fluid should be a redish pinkish colour and not burnt smelling. If it looks Ok and it is low top it up and see how it runs after that.
Old 09-18-2007, 12:07 PM
welcome to the Forum! Cadillacgirly............ Katz is the guy to talk with....... enjoy the Forum.... look around and get yourself counted in Cadillac Demographics, under Off Topic...... later
Old 09-18-2007, 12:21 PM
ORIGINAL: CadillacGirly
[sm=helpout.gif]
after you do what Katz recommended ..
four other things .
1.
welcome
2.
https://www.cadillacforum.com/fb.asp?m=12170
https://www.cadillacforum.com/m_7219/tm.htm
4.
codes?
Old 09-19-2007, 12:34 AM
Thanks! I'll be sure to come by if I have any other questions!
Jamie Ryan
Old 10-02-2007, 08:50 AM
Jamie Ryan
Jamie,
how is the transmission doing ?
SuzielovesCaddy
Automatic Transmissions
04-25-2011 10:53 PM
kamikazee
03-14-2009 07:06 PM
chazmag
08-20-2008 01:17 PM
nickbeardslee
12-10-2007 09:08 AM
sfrench1958
05-17-2006 12:09 AM
Quick Reply: Do I Need A New Overdrive or Transmission?
