98 deville cackling trans
Old 01-19-2008, 01:54 PM
cruella98's Avatar
Default 98 deville cackling trans
when my 98 gets warm and is idling in any gearEXCEPTpark for neutral, i get a semi-loud cackling noise prob from the trans.
wtf is going on?! any ideas?!
thanks!
Old 02-02-2008, 12:25 PM
Big5DoubleZero's Avatar
Default RE: 98 deville cackling trans
Does this noiserise and fall with RPM of the engine while in a drive gear? or just constant.
Old 02-23-2008, 08:52 PM
carnut's Avatar
Probable cracked flex plate. Find a way to look at the bottom of the torque converter. Usually a cracked flex plate will have rust stains down from the cracked bolt hole holding it to the torque converter. Rather common failure.
Old 03-01-2008, 12:25 PM
carnut's Avatar
Would appreciate a response to the noise. Did you find the cause?
OrangePhantom
Automatic Transmissions
09-01-2008 04:34 AM
novass450hp
05-04-2008 10:47 PM
scottie@hottie
01-04-2008 08:12 PM
fishnmachine
06-30-2007 02:03 AM
NickMorgan
11-01-2006 03:34 PM
Quick Reply: 98 deville cackling trans
