neutral safety switch
Old 03-16-2011, 09:43 AM
carcesr3's Avatar
Default neutral safety switch
can anyone tell me how to replace the neutral safety switch on 1990 cad seville 4.5 eng
Old 03-16-2011, 09:45 AM
carcesr3's Avatar
can someone tell me how to replace the neutral safety switch on 1990 cad seville 4.5 thank you ron
Old 03-17-2011, 08:29 AM
carcesr3's Avatar
i would appreciate it
Old 03-17-2011, 12:24 PM
Adams' Apple's Avatar
The NSS is on the top of the trans, under where the shifter cable attaches. Remove the 15mm(or 13mm. depending on who worked on it last) nut from the shaft, and remove the shifter lever/cable. There are two 13mm bolts that hold the NSS to the trans. Remove the two bolts, unplug the NSS connector, and pull the NSS up off of the shaft. Installation is just a reverse procedure. You will notice that the shaft, and the NSS have flats on them. These flats need to be lined up properly before the NSS will fit back onto the shaft.
Be SURE to have the parking brake set, or the wheels otherwise blocked to prevent the vehicle from moving IF you accidentally move the shift linkage, and the trans comes out of Park....
hth
Old 03-17-2011, 03:24 PM
carcesr3's Avatar
thank you so much adam i really appre it
ruffy
08-19-2012 08:57 PM
DaveDiP
11-25-2011 04:27 PM
carcesr3
03-17-2011 03:09 PM
eight_05_south
09-14-2010 12:44 PM
Bosshound
09-21-2007 10:15 PM
Quick Reply: neutral safety switch
