93 Deville Trans slipping?
Old 03-31-2011, 10:46 PM
OrangePhantom's Avatar
Exclamation 93 Deville Trans slipping?
Car runs fine at idle and WOT, only under partial throttle and light load does it surge/slip/buck/misfire. No computer codes. Dealer said transmission was slipping and replaced it and computer (ECU) - same problem. Replaced plugs, wires, dist. cap and rotor, ignition coil and oxygen sensor - same problem. Been to several diagnostic shops - no answers. What are the odds of a new transmission having the exact same problems as the old transmission? I'm beginning to think maybe the dealer charged me for a new transmission but didn't install it. Any ideas?
Old 04-01-2011, 12:20 PM
Adams' Apple's Avatar
Has anyone checked the EGR system?
It is possible the torque converter is causing the problem, but that usually ONLY occurs during lock-up apply...not once the converter is fully applied, and not under steady driving conditions.
The description sounds more like an EGR problem to me. Or possibly a vacuum leak somewhere. The transmission cannot cause a misfire.
edelen
02-07-2015 12:00 AM
HOLDING-ON
Automatic Transmissions
03-02-2014 03:22 PM
mnmstoy
12
03-07-2009 11:10 AM
OrangePhantom
09-01-2008 04:34 AM
greasemonkey
03-31-2007 09:21 PM
Quick Reply: 93 Deville Trans slipping?
