'83 Eldorado Transmission
Old 06-13-2011, 09:01 PM
dphillipps's Avatar
Default '83 Eldorado Transmission
Does the '83 Eldorado have a 4 speed automatic with lock up converter or is it really a 3 speed with the torque converter lock up providing a '4th' gear? I don't ever feel the torque converter locking or unlocking.
Thanks in advance for your comments!
Old 06-13-2011, 10:21 PM
Cadsforfun's Avatar
Default Trans.
Reasons for the no lockup could be several.Check for 12 v at the solenoid or maybe bad connectors.Defective pressure switch or converter clutch apply valve stuck. Have you kept the tranny oil clean on a prescribed basis??
Old 06-24-2011, 04:10 PM
Adams' Apple's Avatar
That car has the 325-4L trans, which IS an Overdrive/4 speed unit, with TCC(torque converter lock-up)
No lock-up could be a brake switch that is not adjusted properly. Does the cruise control work? If so, when you press on the brake, does it dis-engage? It is the same brake switch for the cruize and the TCC.
mysterygirl305
03-26-2009 07:58 AM
Lord Iffy
Automatic Transmissions
09-13-2008 02:38 PM
marky292006
04-19-2008 12:09 AM
Luke9286
12-31-2007 12:59 PM
marky292006
04-03-2007 11:52 PM
Quick Reply: '83 Eldorado Transmission
