4t80e takes off in second gear
RE: 4t80e takes off in second gear
ORIGINAL: mikealaimee
i have a 94 seville with 134,000.it takes off in second gear even in manaul low.doesnt seem to slip,all other gears are ok.any ideas where to start?thank you
These transmissions are famous for BAD shift sylanoids. There are two that are inside the transmission. if this is the problem you might as well replace both at the same time. I did the job once and it is very messy but can be done without pulling the transmission. You have to pull the valve body and open it up to replace them. Parts were less than a $100.00 but be perpaired to have lots of transmission fluid everywhere.
Mac
Mac
ORIGINAL: vpmac
These transmissions are famous for BAD shift solenoids. There are two that are inside the transmission. if this is the problem you might as well replace both at the same time. I did the job once and it is very messy but can be done without pulling the transmission. You have to pull the valve body and open it up to replace them. Parts were less than a $100.00 but be prepared to have lots of transmission fluid everywhere.
Mac
Mac
Macko11586
06-16-2009 10:40 AM
paulrosin
Automatic Transmissions
11-14-2008 06:13 PM
