4T80E solenoid shift replacement 1-2/2-3
Old 03-19-2009, 01:17 PM
El Diggy's Avatar
Question 4T80E solenoid shift replacement 1-2/2-3
I've posted this once before, but not here, so here I go again. I need to do a solenoid shift replacement on a 4T80E. I have the Chilton repair manual but doesn't show the procedure. I've read alot of post and they've all said that the job was more of a mess than it is hard, but I would like to get my hands on a diagram of the 4t80e and know exactly what it is I'm dealing with. Also, I heard alot about some "check *****"? Any info would greatly be appreciated.
Old 03-19-2009, 07:36 PM
If you get the solenoid kit from GM, it will come with instructions. Kit contains both shift solenoids, bracket,& a filter to be installed in valve body.
Old 03-19-2009, 11:42 PM
El Diggy's Avatar
Thumbs up
Thank you so much!!!!!!
Jason
09-06-2011 09:01 PM
dksob81
Automatic Transmissions
03-07-2009 06:00 AM
LCD
08-20-2006 11:09 PM
67camaro
07-03-2006 09:05 PM
Quick Reply: 4T80E solenoid shift replacement 1-2/2-3
