2000 Eldorado seems to slip
Old 06-25-2009, 12:25 PM
walted's Avatar
Default 2000 Eldorado seems to slip
Hi:
I have a 2000 Eldorado that at low speeds under light acceleration feels like it is going from low gear through neutral on it's way to second gear. The car has 143K on it (last 60K by me) and I have never had anything done to the transmission. The delay is no more than a second. What do you suggest? Do you think it would help or hurt to change the fluid and filter at this point? Also read some threads talking about the TCC solenoid. Any possibilities there?
Thanks
Old 06-25-2009, 03:27 PM
Originally Posted by walted
Hi:
Thanks
maybe, but it could also be the clutch plates.
add a bottle of Lucas, drive it easy for a couple of days, then change the fluid and filter adding two bottles of LUCAS .. do not overfill .. drive it easy for a couple of days, then back to normal driving.
cross your fingers that its fine after that.
the Lucas is amazing at times but it cant fix everything.
Cgcgirl
06-19-2011 07:43 PM
08-04-2007 01:00 PM
Automatic Transmissions
07-31-2007 10:56 AM
sqzdog
07-01-2007 10:45 AM
InfraredV
09-01-2006 02:11 AM
Quick Reply: 2000 Eldorado seems to slip
