1992 cadillac deville tranny slipping
Old 03-02-2009, 09:14 PM
E40 relates to P/S switch, should not cause you problem. I suggest to check vacuum to modulator, with hose off throttle body when engine running port should whistle, many times T/Body ports can carbon up causing a delayed or weak signal to modulator causing slipping. Also take exhaust loose from y pipe to check for restricted cat.conv. on drive car. MAKE SURE IT WONT FALL DOWN AND HIT ROADWAY. Post what you find.
  #12
Old 03-05-2009, 09:30 PM
mnmstoy's Avatar
dropped it off at my mechanics shop today. We will see how it goes tomorrow.
Mike
  #13
Old 03-07-2009, 11:10 AM
mnmstoy's Avatar
k here is what the mechanic said. I have dirty fuel injectors.
I'm going to try a fuel injector additive in the gas tank and take it from their.
I still get E40...EE40 I have replaced the PSP switch. I'll have to look for other stuff on the power steering.
Until then....I'll keep posting my findings.
Mike
HOLDING-ON
Automatic Transmissions
03-02-2014 03:22 PM
OrangePhantom
04-01-2011 12:20 PM
OrangePhantom
09-01-2008 04:34 AM
10-14-2007 04:18 PM
greasemonkey
03-31-2007 09:21 PM
Quick Reply: 1992 cadillac deville tranny slipping
