What is code 1\I027 PRND321 - Cadillac Forum - Enthusiast forums for Cadillac Owners
LinkBack Thread Tools Search this Thread
Old 10-23-2008, 06:40 PM
Default What is code 1\I027 PRND321
What is the world is the code I027 PRND321 switch? Can it make driveability problems because my car is barely running.
Old 10-24-2008, 08:56 AM
Default RE: What is code 1\I027 PRND321
I had a problem once or twice with my prnd321 lights on my dash flashing while in drive. The floor shifter didn`t feel in right position, but I didn`t try to pull codes at that time. I`ll be watching to see if you get an answer to your problem, as it may be mine also.
Old 10-24-2008, 09:01 AM
Default I027 PRND321 switch failure code
which car , model, year?
other codes ? driveability ?
not enough info provided
for the I027 PRND321 switch failure code, typically, neutral switch on transmission is with issues.
Disconnect battery ground cable.
Disconnect shift cable from transaxle.
Disconnect electrical connector from switch.
Remove switch mounting bolts and switch.
Align flats on switch with flats on transaxle shaft and push switch over shaft and fully seat on transaxle.
Install and torque switch mounting bolts to 20 ft. lbs. If switch was rotated and pin is broken, switch will be automatically reset to neutral position as follows:
Place transaxle shaft in neutral position.
Install switch on transaxle and loosely install mounting bolts.
Insert a 3/32 inch gauge pin into service adjustment hole of switch.
Rotate switch until pin drops in detent.
Torque mounting bolts to 20 ft. lbs.
buy a factory service manual !
Old 10-27-2008, 11:34 AM
Default RE: I027 PRND321 switch failure code
As far as my problem, it`s for my 2001 eldo.
evap code and maf code joshholman Cadillac STS 0 03-13-2010 07:25 PM
I027 PRND321 switch? jsjag Cadillac Deville 0 10-23-2008 06:39 PM
Tags
01, 2005, cable, caddilac, cadillac, code1, codes, failure, prnd321, remove, shaft, shifter, sts, transaxle, transission, xlr
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
