gopher
10/16/2007 8:44:37 PM
Car failed the nox .
Cat and O2 sensor changed... now check engine light flashes when
idling in park intermittently..
Does the computer need resetting with the new smog crap installed?
10/16/2007 11:07:33 PM
quote:
ORIGINAL: gopher
I would reset .. nothing to lose.
your car has an air pump?
if it does, test it, check the hoses, make sure the new CAT has the air inlet hooked up and working.
also, check the codes - the flashing light
slowroll
10/17/2007 7:24:54 PM
On a 1989 Cadillac ses light should not flash, if it comes on there should be a code stored. However, if some one put at jumper in the ALDL located under center of dash it will flash , I would check for it. Make sure EGR works because thats what it there for, to reduce NOx Hope it helps
gopher
10/18/2007 1:58:41 PM
Thanks for the info.
Will check them out...
Does dealer need to reset computer?
slowroll
10/22/2007 5:57:01 PM
computer does not need reset. Steel tubes under throttle body tend to carbon up, can be cleared with 3/8" drill bit. Does engine have spark knock with timing set correctly on 91+ octane?
gopher
10/25/2007 12:51:09 AM
Hi.
Been away for couple of days..
Thanks for the tip. will check it out..
no knock on 91 . Never had any pinging with her all the years I ve had her...
